Steca WR über LAN auslesen
    hat das schon jemand gemacht?
    Hat der Steca eine XML Schnittstelle?
    Gruß Verona
    12 kW ESS Peus-Testing
    Die Beschreibung der Ethernet-Schnittstelle inkl. XML bekommst du von Steca, wende dich an Hr. Manuel Wiedemann (Manuel.Wiedemann@Steca.de).
    Das sieht dann z.b. so aus:
    Code
    $ ftp -a -o - http://sonne.catai.org/measurements.xml
    Trying 192.168.1.10...
    Requesting http://sonne.catai.org/measurements.xml
    <?xml version='1.0' encoding='UTF-8'?><root><Device Name='StecaGrid 4803' Type='Inverter' Serial='XXXXXXXXXXXX' BusAddress='1' NetBiosName='SONNE' IpAddress='192.168.1.10' DateTime='2015-12-30T11:36:32'><Measurements><Measurement Value='235.290' Unit='V' Type='AC_Voltage1'/><Measurement Value='234.924' Unit='V' Type='AC_Voltage2'/><Measurement Value='234.376' Unit='V' Type='AC_Voltage3'/><Measurement Value='4.368' Unit='A' Type='AC_Current1'/><Measurement Value='4.355' Unit='A' Type='AC_Current2'/><Measurement Value='4.350' Unit='A' Type='AC_Current3'/><Measurement Value='3062.808' Unit='W' Type='AC_Power'/><Measurement Value='1027.729' Unit='W' Type='AC_Power1'/><Measurement Value='1021.597' Unit='W' Type='AC_Power2'/><Measurement Value='1018.294' Unit='W' Type='AC_Power3'/><Measurement Value='50.039' Unit='Hz' Type='AC_Frequency1'/><Measurement Value='50.040' Unit='Hz' Type='AC_Frequency2'/><Measurement Value='50.026' Unit='Hz' Type='AC_Frequency3'/><Measurement Value='492.100' Unit='V' Type='DC_Voltage'/><Measurement Value='6.348' Unit='A' Type='DC_Current'/><Measurement Value='3123.851' Unit='W' Type='DC_Power'/><Measurement Value='32.990' Unit='°C' Type='Temp'/></Measurements></Device></root>
    1239 bytes received in 0.00 seconds (312.73 KB/s)
    #1: Huawei SUN2000-33KTL-A mit 81x Q.PEAK L-G4.5 365 Ost/West + 20x Yingli YL250P-29b Süd
    #2: Solaredge SE3500H mit 5x Q.PEAK L-G4.5 365 Süd, 2x Trina 275 Süd, 1x LG 350 NeoN Süd, 2x Kioto 220 Nord
    eGolf300 als Drittauto
    1. Famoser Großkaiserlicher JK: 1er: 172 2er: 44, 3er: 24, 4er: 8, 5er: 7, 6er: 4, 7er-14er: 1
    Danke das hat mir schon geholfen...
    http://IP-Adresse/measurements.xml --> XML Daten vom WR
    Gruß Verona
