Hallo zusammen!
Habe seit einigen Monaten bei mir den Volkszähler an 2 ISKRA MT681 erfolgreich laufen.
Nun habe ich vorhin mal in mein Frontend geschaut und da war nix mehr. Dann schaute ich in mein HTML was mir die Zählerstände jeden Tag anzeigt und da stand ab 29.07. nix mehr drin.
Mal ein Auszug der Logdatei:
Code
[Jul 08 18:04:12][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?)' with params [1436368667271.4, 393$
[Jul 08 18:04:43][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:05:14][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:05:44][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:06:15][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:06:45][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:07:16][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:07:47][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:08:17][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:08:48][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:09:19][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:09:50][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:10:20][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:10:51][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:11:23][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:11:54][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[[Jul 08 18:12:25][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:12:57][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:13:29][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:14:01][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:14:33][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:15:08][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:15:41][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:16:13][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:16:46][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:17:19][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:17:52][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:18:26][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:19:00][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:19:34][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:20:08][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:20:44][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:21:20][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:21:55][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:22:31][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:23:08][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:23:44][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:24:22][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:25:00][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:25:37][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:26:16][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:26:55][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:27:36][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:28:16][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[[Jul 08 18:29:39][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:30:21][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:31:03][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:31:46][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:32:30][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:33:16][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:34:03][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:34:50][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:35:38][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:36:27][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:37:18][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:38:10][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:39:05][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:40:00][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:40:56][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
[Jul 08 18:41:55][chn3] CURL Error from middleware: 'DBALException': 'An exception occurred while executing 'INSERT INTO data (channel_id, timestamp, value) VALUES (4,?,?), (4,?,?), (4,?,?), (4,?,?), (4,?,?$
