Ich bin so weit das ich meine Daten in PVoutput angezeigt bekomme.
Für ein paar Werte wurde auch die Temperatur und die Spannung angezeigt bzw. exportiert.
Nun aber nicht mehr ???
Hier die Log-Datei von heute mit der ich aber nicht viel anfangen kann.
Jemand eine Idee wo ich suchen muss bzw. was für Infos ihr benötigt um mir weiterzuhelfen ?
Code
00:08:46] INFO: Starting SBFspotUploadDeamon Version 1.0.1
[00:08:46] INFO: Starting Daemon...
[01:05:57] WARNING: Gruener Weg is not yet member of SBFspot Team. Consider joining at http://pvoutput.org/listteam.jsp?tid=613
[03:06:20] WARNING: Gruener Weg is not yet member of SBFspot Team. Consider joining at http://pvoutput.org/listteam.jsp?tid=613
[05:06:43] WARNING: Gruener Weg is not yet member of SBFspot Team. Consider joining at http://pvoutput.org/listteam.jsp?tid=613
[07:07:12] WARNING: Gruener Weg is not yet member of SBFspot Team. Consider joining at http://pvoutput.org/listteam.jsp?tid=613
[09:07:41] WARNING: Gruener Weg is not yet member of SBFspot Team. Consider joining at http://pvoutput.org/listteam.jsp?tid=613
[09:55:54] INFO: Uploading 30 datapoints, starting with 20150222,07:10,8509994,0 => OK (200)
[10:05:02] INFO: Uploading 2 datapoints, starting with 20150222,10:05,8511577,456,,,29.9,237.36 => OK (200)
[10:05:02] ERROR: batch_set_pvoflag() returned database is locked
[11:10:10] INFO: Uploading datapoint: 20150222,10:15,8511638,444 => OK (200)
[11:10:10] ERROR: batch_set_pvoflag() returned database is locked
[11:11:16] INFO: Uploading datapoint: 20150222,11:15,8511638,444 => OK (200)
[11:25:25] INFO: Uploading 3 datapoints, starting with 20150222,11:20,8511686,576 => OK (200)
[11:25:25] ERROR: batch_set_pvoflag() returned database is locked
[11:44:36] INFO: Uploading 2 datapoints, starting with 20150222,11:45,8512019,636,,,30.1,235.38 => OK (200)
[11:55:44] INFO: Uploading datapoint: 20150222,12:00,8512199,468 => OK (200)
[11:55:44] ERROR: batch_set_pvoflag() returned database is locked
[12:05:53] INFO: Uploading datapoint: 20150222,12:10,8512257,348 => OK (200)
[12:05:53] ERROR: batch_set_pvoflag() returned database is locked
[12:11:00] INFO: Uploading datapoint: 20150222,12:15,8512291,408 => OK (200)
[12:15:07] INFO: Uploading datapoint: 20150222,12:20,8512338,564 => OK (200)
[12:20:15] INFO: Uploading datapoint: 20150222,12:25,8512383,540 => OK (200)
[12:20:15] ERROR: batch_set_pvoflag() returned database is locked
[12:25:24] INFO: Uploading datapoint: 20150222,12:30,8512418,420 => OK (200)
[12:25:24] ERROR: batch_set_pvoflag() returned database is locked
[12:30:32] INFO: Uploading datapoint: 20150222,12:35,8512457,468 => OK (200)
[12:35:40] INFO: Uploading datapoint: 20150222,12:40,8512505,576 => OK (200)
[12:40:49] INFO: Uploading datapoint: 20150222,12:45,8512573,816 => OK (200)
[12:45:57] INFO: Uploading datapoint: 20150222,12:50,8512660,1044 => OK (200)
[12:45:57] ERROR: batch_set_pvoflag() returned database is locked
[12:51:05] INFO: Uploading datapoint: 20150222,12:55,8512716,672 => OK (200)
[12:51:05] ERROR: batch_set_pvoflag() returned database is locked
[12:55:13] INFO: Uploading datapoint: 20150222,13:00,8512777,732 => OK (200)
[12:55:13] ERROR: batch_set_pvoflag() returned database is locked
[13:05:23] INFO: Uploading datapoint: 20150222,13:10,8513043,1044 => OK (200)
[13:05:23] ERROR: batch_set_pvoflag() returned database is locked
[13:10:31] INFO: Uploading datapoint: 20150222,13:15,8513251,2496 => OK (200)
Alles anzeigen
