Schreiben ENVERTECH zu Fragen aus dem PV Forum
Beitragvon FelzenSolar » 31.08.2017, 14:10
Dear Bosswerk team,
Guten Morgen,Recently i noticed a user in "Photovoltaik-Forum" wants to connect 2 - 3 solar panels in parallel to an EVT248.
I got reply from our tech team:
- it’s technically workable, and our inverter will not break.
- the warranty of microinverter would still be 25 years.
But if connect with 2 panels in one EVT248 have some disadvantages:
• Two panels in parallel means there are two MPPT points inverter has to track. However, EVT248 cannot track two MPPT points at the same time, So EVT248 might goes into an unstable state, working normally for a while and even stopped working for a while due to MPPT Malfunction. The efficiency of both panels we cannot guarantee to reaches the highest.
• What’s more, Even though it can work, like in the afternoon, the efficiency and power of two panels will all be wasted.
Also I noticed some customers mentioned EVT248 is too “warm”,
Actually EVT can work in the environment temperature up to 65℃. and internal temperature up to 105℃. so customers don't need to worry about the“warm”problem:-)
Wish you have a nice day.
________________________________________
Best Regards,
Phibon Chen http://www.envertec.com
Sales Manager Skype: phibon.chen
______________________________________________________________________________________________________________
Zhejiang Envertech Corporation Ltd.
24th Floor, Jintong Mansion, Center of Headquarters, Yongkang City, Zhejiang Province, China
FelzenSolar
Info: Händler
Re: Schreiben ENVERTECH zu Fragen aus dem PV Forum
Beitragvon black » 31.08.2017, 14:45
also der verfasser dieses textes hat keine ahnung von technik...bei parallelen modulen gibt es (wie immer) auch nur einen MPP :idea:
6,97kwp - 34xTrina TSM -DC80.08 205W - Danfoss TLX+ pro 8k
Ausrichtung: -14°/DN28°
Standort: N47.19462 O016.3165
http://clxportal.danfoss.com/index.php? ... 9&end=TRUE
black
PV-Anlage [kWp]: 6,97
Beitragvon PV-Express » 31.08.2017, 14:47
gibts das auch auf deutsch?
und welche Fragen hat das PV-Forum gestellt?
Renault ZOE Z.E.40
PV-Express
PV-Anlage [kWp]: 8,97
Beitragvon qualiman » 31.08.2017, 14:52
black hat geschrieben:also der verfasser dieses textes hat keine ahnung von technik...bei parallelen modulen gibt es (wie immer) auch nur einen MPP :idea:
Auch wenn der Verfasser den Fall einer Verschattung von einem parallelgeschalteten Modul vielleicht nicht im Sinn hatte, so kann es hier doch für jedes Modul einen eigenen MPPT geben, auch bei gleicher Modulausrichtung.
qualiman
PV-Anlage [kWp]: 9,6
Beitragvon kalle bond » 31.08.2017, 15:04
qualiman hat geschrieben:
Sicher hat jedes Modul seinen eigenen MPPT und weicht leicht von anderen Modulen gleichen Typs ab.
Da sich die Werte dauernd während des Tages ändern spielt das bei zwei parallel geschalteten Typen keine Rolle.
Der Inverter sieht eine IV Kurve. Daher kommt nicht das Ideal dabei raus. Insgesamt erhöht sich der Ertrag signifikant gegenüber einem Modul und das ist es, was der vorige TS erreichen wollte.
kalle bond
PV-Anlage [kWp]: 13,54
Info: Berater
Beitragvon black » 01.09.2017, 10:15
@kalle :danke: genau so hab ich es gemeint. der wr sieht nur 1 mpp und fertig
black
Beitragvon playboy » 01.09.2017, 11:17
Die Frage nach den 25 Jahren Garantie wird aber extra nicht erwähnt :lol:
playboy
PV-Anlage [kWp]: 0,5
Beitragvon kalle bond » 01.09.2017, 11:55
playboy hat geschrieben:Die Frage nach den 25 Jahren Garantie wird aber extra nicht erwähnt :lol:
2.3 in der B-Note :?
"I got reply from our tech team:
- the warranty of microinverter would still be 25 years."
kalle bond
Info: Berater
Beitragvon qualiman » 01.09.2017, 11:56
kalle bond hat geschrieben:
Für die Teil-/Verschattung eines Modules, was zwei wesentliche verschiedene MPPT´s bedeutet, so ist die Aussage von Envertec nicht als disqualifizierend zu sehen.
qualiman
Beitragvon CarpeDiem » 02.09.2017, 14:08
... Tja so entlarven sich selbsternannte "Experten":
Natürlich hat bei parallel geschalteten PV-Modulen jedes seine eigene Kennlinie (selbst wenn die Module aus dem gleichen Produktions-Batch sindI). Dadurch ist die Gesamtkennlinie nicht mehr monoton und führt unter Umständen zur Einstellung des Wechselrichter - MPPTs auf ein lokales Maximum.
Paul Wieland
CarpeDiem Energy
Energiemanager ecoControl, Speicher ecoStore
Wir sind Service- und Vertriebspartner von LetrikaSol, Envertech und Zeversolar
Wir kämpfen für eine nachhaltige, dezentrale Energieversorgung
CarpeDiem
PV-Anlage [kWp]: 0,25
Info: Hersteller
Zurück zu PV-Anlage ohne EEG
Mitglieder in diesem Forum: peter45 und 1 Gast
