Was heisst "grid-tie inverter" in Deutsch?
Beitragvon Evalon » 19.09.2010, 21:05
Hello,
I hope it's ok that I post here in English - please feel free to reply in German.
I have a question which is what a "grid-tie inverter" is called in German? I need to find a ~600- 1000 watt grid-tie inverter and am considering buying it in Germany but don't know the name of it ...
Help is appreciated :-)
Greetings,
Jesper
Evalon
PV-Anlage [kWp]: 0,4
Re: Was heisst "grid-tie inverter" in Deutsch?
Beitragvon wieso » 19.09.2010, 21:14
Hi and welcome
grid-tie inverter is called "Netzwechselrichter " in German "Netz" is like the Grid and Wechselrichter means inverter
All the best
Lars
and Stecca makes small grid tie inverters (stecca 300 0r 500 i think ) and a Mastervolt soladin (Dutsch ) another option
SMA sunny boy has a 1200 watt one as far as i know .... good luck
Zuletzt geändert von wieso am 19.09.2010, 21:18, insgesamt 1-mal geändert.
Irland ;
wieso
Beitragvon Evalon » 19.09.2010, 21:17
Vielen Dank!
Likewise,
Jesper
Evalon
Beitragvon wieso » 20.09.2010, 03:24
:wink: true forgot Dorfmüller
Die Wechselrichter Daten Bank scheint neu zu sein ..... nur unter der Abteilung "off-grid" solte man Netzwechselrichter nicht listen :wink:
wrdatabase_dir.php
Irland ;
wieso
Beitragvon Cheook » 20.09.2010, 08:07
Netzgeführter Wechselrichter (if it follows voltage and frequency of the grid)
Insel-Wechselrichter (if it can build up its own voltage and frequency)
Cheook
Info: Berater
Zurück zu Wechselrichter
