 Sunny Webbox export data in MySQL using PHP and cron Nächstes Thema anzeigen
arthur
Angemeldet: 27.03.2008
BeitragVerfasst am: 28.03.2008, 13:31 Nach oben
First of all sorry for not writing in German, I do understand it but writing it is somewhat diffcult for me Embarassed
Anyway, for all of you who are wrestling with getting the data out of the webbox and into MySQL I created a PHP script.
With this script you can pull the data out of the Sunny Webbox and into the MySQL database. The code is based on that of czan from this topic:
http://www.photovoltaikforum.com/ftopic10880.html
With a cron job on your webserver you can automatically execute the php script.
My cron job looks like this:
Code:
15 * * * * /usr/bin/php -q /srv/www/htdocs/sunny_input.php
My script gets executed every 15 minutes.
The SQL script to create the table in MySQL looks like this:
Code:
CREATE TABLE IF NOT EXISTS `eco_data` (
  `id` int(100) NOT NULL auto_increment,
  `timestamp` varchar(12) NOT NULL,
  `cur_power` varchar(255) NOT NULL,
  `cur_energy` varchar(255) NOT NULL,
  `total_energy` varchar(255) NOT NULL,
  PRIMARY KEY  (`id`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=18 ;
And last but not least, here is my PHP script Laughing
Code:
$hostname = "mysql.host.com";
$database = "webbox";
$username = "sunny";
$password = "sunny";
$webboxip = "10.10.40.50";
//any data below should not be edited...
//setup link with MySQL server/database
$ECO = mysql_pconnect($hostname, $username, $password) or trigger_error(mysql_error(),E_USER_ERROR);
//JSON Request im PHP Array Format (will be transformed afterwards with the PHP 5.2 json_encode/decode function)
$requestarray = array(
'version'=>"1.0",
'proc'=>"GetPlantOverview",
'id'=>"1",
'format'=>"JSON"
//encode array in JSON
$request = json_encode($requestarray);
//do the JSON request
$request = 'RPC='.rawurlencode($request);
$ch=curl_init();
curl_setopt($ch, CURLOPT_URL, "http://".$webboxip."/rpc");
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_FOLLOWLOCATION,1);
curl_setopt($ch, CURLOPT_HEADER , 0);
curl_setopt($ch, CURLOPT_POST, 1 );
curl_setopt($ch, CURLOPT_POSTFIELDS, $request);
//here is the result of the request
$response = curl_exec ($ch);
if (curl_errno($ch)) {
    $err=1;
      $errtext = curl_error($ch);
curl_close($ch);
//decode the answer
$response = json_decode($response);
//put the values into variables
$cur_power = $response->result->overview[0]->value/1000;
$cur_energy = $response->result->overview[1]->value;
$total_energy = $response->result->overview[2]->value;
//create a timestamp
$timestamp = date("YmdHi");
//build a SQL statement for our database
$insertSQL = "INSERT INTO eco_data (timestamp, cur_power, cur_energy, total_energy) VALUES (
                $timestamp,
                $cur_power,
                $cur_energy,
                $total_energy)";
//select the database we defined and execute the SQL statement
mysql_select_db($database, $ECO);
$invoer = mysql_query($insertSQL, $ECO) or die(mysql_error());
//optionally show the variables to check the values with a browser
// echo $timestamp."<br>";
// echo $cur_power."<br>";
// echo $cur_energy."<br>";
// echo $total_energy."<br>";
// echo $insertSQL;
Enjoy Wink
arthur
pesoelko
Angemeldet: 05.07.2006
BeitragVerfasst am: 31.03.2008, 22:15 Nach oben
Ebenfalls hochschieb-
Peter
P.W.ab 05.08.2006
